Inleiding
This guide will demonstrate how to dismantle and replace components of your computers display (screen).
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Remove the keyboard. For keyboard removal instructions, see the keyboard guide here: Toshiba Satellite M45 Keyboard Replacement
Remove the black electrical tape covering the black-and-white antenna cable. There will be 2-3 pieces of tape.
After the tape has been removed, close the laptop display, flip the laptop over, and disconnect the black-and-white antenna cables from the WiFi Card.
For information about accessing the WiFi Card, see the WiFi Guide here: Toshiba Satellite M45 Wi-Fi Card Replacement
Once the antenna cables are disconnected from the modem card, flip the laptop back over and open the display.
Remove the two screws securing the display hinges with a #1 size Phillips head screwdriver. It is recommended to keep the screws in a small cup so that you don't lose them.
Remove the four screws on the back of the laptop holding the screen in place with a #1 screwdriver. There are two on each side.
3 andere personen hebben deze handleiding voltooid.
