Ga door naar hoofdinhoud
Toshiba Satellite M35X-S114 Hard Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite M35X-S114 Hard Drive Replacement, Unlock the Battery from its Compartment: stap 1, afbeelding 1 van 2 Toshiba Satellite M35X-S114 Hard Drive Replacement, Unlock the Battery from its Compartment: stap 1, afbeelding 2 van 2
    • Locate the battery near the bottom left-hand side of the device.
    • Locate the two switches above the battery's top left corner.
    • Use any finger to move the smaller switch above the battery to the unlock position.
    • A small icon of a padlock will identify the "lock" and "unlock" positions of the switch.
  2. Toshiba Satellite M35X-S114 Hard Drive Replacement, Move the Battery's Release Switch: stap 2, afbeelding 1 van 2 Toshiba Satellite M35X-S114 Hard Drive Replacement, Move the Battery's Release Switch: stap 2, afbeelding 2 van 2
    • Use any finger to move the larger switch above the battery to the left and hold the switch.
  3. Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Battery: stap 3, afbeelding 1 van 2 Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Battery: stap 3, afbeelding 2 van 2
    • Place your fingernail or fingertip into the groove near the top right of the battery.
    • Pull the battery out with your finger. Release the larger switch once the battery is out.
  4. Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Hard Drive screw: stap 4, afbeelding 1 van 3 Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Hard Drive screw: stap 4, afbeelding 2 van 3 Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Hard Drive screw: stap 4, afbeelding 3 van 3
    • Locate the Hard Drive.
    • Locate the screw near the Hard Drive.
    • Use a Phillips 00 screwdriver to remove the 7.50mm screw.
  5. Toshiba Satellite M35X-S114 Hard Drive Replacement, Slide the Hard Drive out: stap 5, afbeelding 1 van 2 Toshiba Satellite M35X-S114 Hard Drive Replacement, Slide the Hard Drive out: stap 5, afbeelding 2 van 2
    • Please note that the hard drive from the laptop used is missing.
    • Slide the hard drive out.
    • The hard drive may not slide out easily, and may require a little bit of force in order to be disconnected from the laptop.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Christian Mayorga
219 Reputatie
2 handleidingen geschreven
CSU Fullerton, Team 2-4, Bruce Fall 2014 Lid van CSU Fullerton, Team 2-4, Bruce Fall 2014
CSUF-BRUCE-F14S2G4
4 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 32
Altijd: 1,735
