Ga door naar hoofdinhoud
Toshiba Satellite M35X-S114 Battery Replacement
  1. Toshiba Satellite M35X-S114 Battery Replacement, Unlock the Battery from its Compartment: stap 1, afbeelding 1 van 2 Toshiba Satellite M35X-S114 Battery Replacement, Unlock the Battery from its Compartment: stap 1, afbeelding 2 van 2
    • Locate the battery near the bottom left-hand side of the device.
    • Locate the two switches above the battery's top left corner.
    • Use any finger to move the smaller switch above the battery to the unlock position.
    • A small icon of a padlock will identify the "lock" and "unlock" positions of the switch.
  2. Toshiba Satellite M35X-S114 Battery Replacement, Move the Battery's Release Switch: stap 2, afbeelding 1 van 2 Toshiba Satellite M35X-S114 Battery Replacement, Move the Battery's Release Switch: stap 2, afbeelding 2 van 2
    • Use any finger to move the larger switch above the battery to the left and hold the switch.
  3. Toshiba Satellite M35X-S114 Battery Replacement, Remove the Battery: stap 3, afbeelding 1 van 2 Toshiba Satellite M35X-S114 Battery Replacement, Remove the Battery: stap 3, afbeelding 2 van 2
    • Place your fingernail or fingertip into the groove near the top right of the battery.
    • Pull the battery out with your finger. Release the larger switch once the battery is out.
Conclusie
Nathan Jansen
206 Reputatie
1 Handleiding geschreven
CSU Fullerton, Team 2-4, Bruce Fall 2014 Lid van CSU Fullerton, Team 2-4, Bruce Fall 2014
CSUF-BRUCE-F14S2G4
4 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 11
Altijd: 356
