Ga door naar hoofdinhoud
Toshiba Satellite M305D-S4829 Keyboard Replacement
Wat je nodig hebt
  1. Toshiba Satellite M305D-S4829 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Unlatch the battery by pushing outward on both latches.
  2. Toshiba Satellite M305D-S4829 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Slide battery out.
  3. Toshiba Satellite M305D-S4829 Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 1
    • Remove the five "F2" screws with a Phillips #0 screwdriver.
  4. Toshiba Satellite M305D-S4829 Keyboard Replacement: stap 4, afbeelding 1 van 2 Toshiba Satellite M305D-S4829 Keyboard Replacement: stap 4, afbeelding 2 van 2
    • Insert the plastic opening tool above the F1 key.
    • Apply upward pressure until the black plastic strip snaps off. The entire strip will easily come off from left to right.
  5. Toshiba Satellite M305D-S4829 Keyboard Replacement: stap 5, afbeelding 1 van 2 Toshiba Satellite M305D-S4829 Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Find the screws above the F1 and INS keys.
    • Unscrew both screws with a Phillips #0 screwdriver.
  6. Toshiba Satellite M305D-S4829 Keyboard Replacement: stap 6, afbeelding 1 van 2 Toshiba Satellite M305D-S4829 Keyboard Replacement: stap 6, afbeelding 2 van 2
    • Slowly lift the top edge of the keyboard out with your fingers.
    • The ribbon cable located on the back of the keyboard will become accessible.
  7. Toshiba Satellite M305D-S4829 Keyboard Replacement: stap 7, afbeelding 1 van 2 Toshiba Satellite M305D-S4829 Keyboard Replacement: stap 7, afbeelding 2 van 2
    • Locate the black ribbon cable flap.
    • Detach flap with plastic opening tool. The ribbon cable will become free.
  8. Toshiba Satellite M305D-S4829 Keyboard Replacement: stap 8, afbeelding 1 van 1
    • Your keyboard has now been successfully removed.
Conclusie
Michael Jensen
425 Reputatie
6 handleidingen geschreven
Cal Poly, Team 4-3, Regan Spring 2011 Lid van Cal Poly, Team 4-3, Regan Spring 2011
CPSU-REGAN-S11S4G3
5 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 4,550
