Onderdelen
Geen onderdelen nodig.
  1. Unlatch the battery by pushing outward on both latches.
    • Unlatch the battery by pushing outward on both latches.
  2. Slide battery out.
    • Slide battery out.
    • Remove the five "F2" screws with a Phillips #0 screwdriver.
    • Insert the plastic opening tool above the F1 key.
    • Apply upward pressure until the black plastic strip snaps off. The entire strip will easily come off from left to right.
    • Find the screws above the F1 and INS keys.
    • Unscrew both screws with a Phillips #0 screwdriver.
    • Slowly lift the top edge of the keyboard out with your fingers.
    • The ribbon cable located on the back of the keyboard will become accessible.
    • Locate the black ribbon cable flap.
    • Detach flap with plastic opening tool. The ribbon cable will become free.
    • Your keyboard has now been successfully removed.
Conclusie
Michael Jensen
417 Reputatie
6 handleidingen geschreven
Cal Poly, Team 4-3, Regan Spring 2011 Lid van Cal Poly, Team 4-3, Regan Spring 2011
CPSU-REGAN-S11S4G3
5 Leden
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 2
Altijd: 4,427
