Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Flip the laptop over and locate the screw beneath the left battery latch.
Use the Phillips #1 screwdriver to remove the screw.
Using a metal spudger, slip it into the groove and gently pry open the cover.
Locate the RAM card at the top left corner closest to the bottom of the battery.
Using two fingers, push the two levers outwards in opposite directions of each other to release the RAM card.
When done correctly, the RAM card should pop up like this.
Remove the existing RAM card and insert the your new RAM by snapping the RAM in place. Make sure the notch on your RAM card matches up with the slot.
