Ga door naar hoofdinhoud
Toshiba Satellite L855-S5119 Random Access Memory Replacement
Wat je nodig hebt
  1. Toshiba Satellite L855-S5119 Random Access Memory Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the laptop face down to expose the back.
    • Locate the battery.
  2. Toshiba Satellite L855-S5119 Random Access Memory Replacement: stap 2, afbeelding 1 van 3 Toshiba Satellite L855-S5119 Random Access Memory Replacement: stap 2, afbeelding 2 van 3 Toshiba Satellite L855-S5119 Random Access Memory Replacement: stap 2, afbeelding 3 van 3
    • Locate the battery latches. The battery latch mechanism can be compared to a door -- The right latch, when pushed right, unlocks the battery, while the left latch, when pushed left, releases the battery, pushing it out from its container.
    • Push the latch on the right to the right to unlock the battery latch locking mechanism.
    • Push the battery latch on the left to the left to unlock the battery.
  3. Toshiba Satellite L855-S5119 Random Access Memory Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite L855-S5119 Random Access Memory Replacement: stap 3, afbeelding 2 van 2
    • With the left battery latch pushed left, remove the battery from its port by lifting the battery from the middle of the battery.
    • The battery will come free.
  4. Toshiba Satellite L855-S5119 Random Access Memory Replacement, Back Plate Removal: stap 4, afbeelding 1 van 3 Toshiba Satellite L855-S5119 Random Access Memory Replacement, Back Plate Removal: stap 4, afbeelding 2 van 3 Toshiba Satellite L855-S5119 Random Access Memory Replacement, Back Plate Removal: stap 4, afbeelding 3 van 3
    • Turn the laptop over to place it top down.
    • Use a Phillips #1 screwdriver to remove the screw holding in the back plate. This screw does not come out of the plate.
    • Lift the back plate off the laptop, exposing the RAM and Hard Disk.
  5. Toshiba Satellite L855-S5119 Random Access Memory Replacement, Random Access Memory: stap 5, afbeelding 1 van 1
    • Locate the Random Access Memory.
  6. Toshiba Satellite L855-S5119 Random Access Memory Replacement: stap 6, afbeelding 1 van 3 Toshiba Satellite L855-S5119 Random Access Memory Replacement: stap 6, afbeelding 2 van 3 Toshiba Satellite L855-S5119 Random Access Memory Replacement: stap 6, afbeelding 3 van 3
    • Pull back the two retention clips holding the RAM in place allowing it to pop up.
    • Remove the RAM by pulling it from the SO-DIMM slot.
Conclusie
Cody Brannen
207 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 396
