Inleiding
This guide will help you gain access to and replace the DC powerport,
Wat je nodig hebt
Turn the laptop over to place it top down.
Use a Phillips #1 screwdriver to remove the screw holding in the back plate. This screw does not come out of the plate.
Lift the back plate off the laptop, exposing the RAM and Hard Disk.
Unscrew the hard drive.
Carefully push the hard drive away from its port. This should not require substantial force.
Lift the hard drive out.
Unscrew the screws circled in red. This includes eleven 6mm screws, and one 5mm screw underneath where the optical drive was housed. All screws can be removed with a Phillips #0 screwdriver.
Carefully remove the back cover. The battery holder contains notches that help hold the case in place, so take care not to break those.
Locate the DC power port. Note the 4-pin connector attaching the port to the motherboard.
Remove the 4 pin female connector from the male connector attached to the motherboard.
Lift the DC power port from the bracket holding it in place.
There are black plastic housings for the wires, holding the wires in position. Remove the red and black wires connecting the DC Port to the 4-pin power connector from underneath the black plastic housings.
Remove the DC Power port and 4 pin connector.
