Inleiding
Replacing the motherboard is a good alternative to purchasing a new computer if you know your motherboard is bad. This is a straightforward procedure that can be done with care and enough time. This guide will show you how to remove and replace the motherboard.
Wat je nodig hebt
Make sure the laptop is unplugged and powered off.
Locate the battery latches on the underside of the laptop.
Pry up the thin narrow strip of facing above the keyboard using the opening tool.
Remove the twelve screws from the underside of the laptop using the Phillips #1 screwdriver.
