Ga door naar hoofdinhoud
Toshiba Satellite L775D-S7340 Keyboard Replacement
Wat je nodig hebt
  1. Toshiba Satellite L775D-S7340 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the laptop is unplugged and powered off.
    • Locate the battery latches on the underside of the laptop.
  2. Toshiba Satellite L775D-S7340 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Slide the right latch to the right until you hear it lock into place.
    • Slide the left latch to the left and hold it.
  3. Toshiba Satellite L775D-S7340 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Slide the battery out towards you.
  4. Toshiba Satellite L775D-S7340 Keyboard Replacement, Keyboard: stap 4, afbeelding 1 van 1
    • Pry up the thin narrow strip of facing above the keyboard using the opening tool.
  5. Toshiba Satellite L775D-S7340 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Remove the four screws securing the keyboard using the T4 Torx screwdriver,
  6. Toshiba Satellite L775D-S7340 Keyboard Replacement: stap 6, afbeelding 1 van 2 Toshiba Satellite L775D-S7340 Keyboard Replacement: stap 6, afbeelding 2 van 2
    • Lift the keyboard slowly using the opening tool and lean it toward touchpad.
    • It will still be held by the connector ribbon. Make sure not to pull out the connector ribbon.
  7. Toshiba Satellite L775D-S7340 Keyboard Replacement: stap 7, afbeelding 1 van 1
    • The ribbon is attached by a white clip. Wedge the white clip up carefully using the spudger. This will release the connector ribbon and you can now remove the keyboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Madeline Park
441 Reputatie
4 handleidingen geschreven
Één opmerking
I need to know how to change a plasma for a Toshiba Satellite L775D-S7340
Cyndi May Evans - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 1,693
