Inleiding
This guide will show you how to remove and replace the CMOS battery.
Wat je nodig hebt
Make sure the laptop is unplugged and powered off.
Locate the battery latches on the underside of the laptop.
Use the Phillips #1 screwdriver to remove the one 4.6 mm screw holding on the cover located on the bottom center of the laptop.
Bijna klaar!
Conclusie
