Ga door naar hoofdinhoud
Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Battery: stap 1, afbeelding 1 van 2 Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Battery: stap 1, afbeelding 2 van 2
    • After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
    • This step should always be done before working on your laptop to minimize electrostatic shock.
  2. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Keyboard: stap 2, afbeelding 1 van 1
    • Using the plastic opening tool carefully pry the plastic strip that sits at the top of the keyboard.
  3. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: stap 3, afbeelding 1 van 1
    • Use the Phillips PH00 to unscrew the four 4mm screws that holds the keyboard in place.
    • Using the plastic opening tool carefully pry your keyboard out without disturbing the cord underneath it.
  4. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: stap 4, afbeelding 1 van 1
    • Remaining is the cord that connects the keyboard to the motherboard. Remove this cord after the tabs are pressed in that releases keyboard.
  5. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Optical Disc Drive: stap 5, afbeelding 1 van 1
    • Use the screwdiver and the Phillips PH00 to unscrew the three, 4mm screws for the RAM compartment
  6. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: stap 6, afbeelding 1 van 2 Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: stap 6, afbeelding 2 van 2
    • Use the Phillips PH00 to remove the 4mm screw that holds the ODD.
    • Slide the ODD outward.
  7. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: stap 7, afbeelding 1 van 1
    • Remove the two 4mm screws and the plate attached to the ODD.
Conclusie
Michael Griskewicz
159 Reputatie
1 Handleiding geschreven
USF Tampa, Team 2-5, Sullivan Fall 2016 Lid van USF Tampa, Team 2-5, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G5
4 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 364
