Ga door naar hoofdinhoud
Toshiba Satellite L755D-S5150 Keyboard Replacement
Wat je nodig hebt
  1. Toshiba Satellite L755D-S5150 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 2 Toshiba Satellite L755D-S5150 Keyboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
    • This step should always be done before working on your laptop to minimize electrostatic shock.
  2. Toshiba Satellite L755D-S5150 Keyboard Replacement, Keyboard: stap 2, afbeelding 1 van 1
    • Using the plastic opening tool carefully pry the plastic strip that sits at the top of the keyboard.
  3. Toshiba Satellite L755D-S5150 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Use the Phillips PH00 to unscrew the four 4mm screws that holds the keyboard in place.
    • Using the plastic opening tool carefully pry your keyboard out without disturbing the cord underneath it.
  4. Toshiba Satellite L755D-S5150 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Remaining is the cord that connects the keyboard to the motherboard. Remove this cord after the tabs are pressed in that releases keyboard.
Conclusie
Replace after you are done with your goal replacement.
Één andere persoon heeft deze handleiding voltooid.
Shaheedah
276 Reputatie
2 handleidingen geschreven
USF Tampa, Team 2-5, Sullivan Fall 2016 Lid van USF Tampa, Team 2-5, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G5
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 11
Altijd: 864
