Inleiding
If your computer has become very slow, crashed frequently, or you simply do not have enough RAM to run a program, this guide will show you how to access and replace RAM sticks.
Wat je nodig hebt
Loosen the two 3mm Phillips #0 screws securing the hard drive panel. The panel will retain the screws, so do not remove them completely.
Remove the panel from the laptop (the hard drive does not need to be removed).
Één opmerking
Nice article, Carter.
Parenthetically, we hoped to find the maximum RAM capacity, as well,
but that is not directly related to the process you illustrate.
