Ga door naar hoofdinhoud
Toshiba Satellite L755-S5244 Motherboard Replacement
Wat je nodig hebt
  1. Toshiba Satellite L755-S5244 Motherboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Unsnap and remove the bar above the keyboard.
  2. Toshiba Satellite L755-S5244 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Unscrew the four 4mm Phillips #0 screws beneath the bar.
  3. Toshiba Satellite L755-S5244 Motherboard Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite L755-S5244 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Pull keyboard up and partially out.
    • Detach conductor ribbon.
    • Slide keyboard out completely.
  4. Toshiba Satellite L755-S5244 Motherboard Replacement, Disk Drive: stap 4, afbeelding 1 van 1
    • Remove the seven 4mm Phillips #0 screws beneath the keyboard.
    • After the screws are removed, remove the face plate to reveal the motherboard.
  5. Toshiba Satellite L755-S5244 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Lift up the flap and there will be two 2 mm Phillips screws beneath that will need to be unscrewed to pull the disk drive out.
  6. Toshiba Satellite L755-S5244 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Now the disk drive will be able to be removed from the motherboard by sliding the drive to the right.
  7. Toshiba Satellite L755-S5244 Motherboard Replacement, Motherboard and Fan: stap 7, afbeelding 1 van 1
    • Carefully remove the 2 conductor ribbons.
    • Do not tear the yellow tape covering the upper conductor ribbon if possible.
    • The lower right ribbon may be removed at either the left or right ends by flipping up the black tab.
  8. Toshiba Satellite L755-S5244 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Remove the indicated conduit by gently pulling it away from the motherboard.
  9. Toshiba Satellite L755-S5244 Motherboard Replacement: stap 9, afbeelding 1 van 3 Toshiba Satellite L755-S5244 Motherboard Replacement: stap 9, afbeelding 2 van 3 Toshiba Satellite L755-S5244 Motherboard Replacement: stap 9, afbeelding 3 van 3
    • Remove the 5mm Phillips #0 screw in the middle of the motherboard, and the 4mm Phillips #0 screw on the upper left near the fan.
    • Remove the four 4mm Phillips #0 screws under the edge covering flaps.
    • Carefully lift out the motherboard and fan.
    • To detach the fan, remove the two 2mm Phillips #0 screws.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 1,139
