Ga door naar hoofdinhoud
Toshiba Satellite L675D-S7016 Top Case Housing Removal
Wat je nodig hebt
  1. Toshiba Satellite L675D-S7016 Top Case Housing Removal, Battery: stap 1, afbeelding 1 van 1
    • Power down the computer and unplug the power adapter.
  2. Toshiba Satellite L675D-S7016 Top Case Housing Removal: stap 2, afbeelding 1 van 1
    • Flip the laptop upside down. Locate the two latches on both sides of the battery.
  3. Toshiba Satellite L675D-S7016 Top Case Housing Removal: stap 3, afbeelding 1 van 3 Toshiba Satellite L675D-S7016 Top Case Housing Removal: stap 3, afbeelding 2 van 3 Toshiba Satellite L675D-S7016 Top Case Housing Removal: stap 3, afbeelding 3 van 3
    • Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
    • Simultaneously slide the latch on the left outwards while pulling the battery towards you.
    • Do not touch the metal connectors on the laptop and the battery.
  4. Toshiba Satellite L675D-S7016 Top Case Housing Removal, Back Panel Removal: stap 4, afbeelding 1 van 1
    • Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
  5. Toshiba Satellite L675D-S7016 Top Case Housing Removal: stap 5, afbeelding 1 van 2 Toshiba Satellite L675D-S7016 Top Case Housing Removal: stap 5, afbeelding 2 van 2
    • Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
    • Work your way around the border of the panel, releasing the rest of the clips.
    • Once all clips are released, lift the cover up and pull towards you.
  6. Toshiba Satellite L675D-S7016 Top Case Housing Removal, Hard Drive: stap 6, afbeelding 1 van 2 Toshiba Satellite L675D-S7016 Top Case Housing Removal, Hard Drive: stap 6, afbeelding 2 van 2
    • Slide the hard drive to the left, using the silver tab.
    • Pull up the silver tab, removing the hard drive from the slot.
    • Do not touch the metal data pins on the hard drive or computer.
  7. Toshiba Satellite L675D-S7016 Top Case Housing Removal, Keyboard: stap 7, afbeelding 1 van 3 Toshiba Satellite L675D-S7016 Top Case Housing Removal, Keyboard: stap 7, afbeelding 2 van 3 Toshiba Satellite L675D-S7016 Top Case Housing Removal, Keyboard: stap 7, afbeelding 3 van 3
    • Pry under the plastic strip, starting on the top right side of the key board with a Heavy Duty Spudger.
    • Once the first corner is raised, use your hand pulling upwards and release the rest of the strip.
  8. Toshiba Satellite L675D-S7016 Top Case Housing Removal: stap 8, afbeelding 1 van 2 Toshiba Satellite L675D-S7016 Top Case Housing Removal: stap 8, afbeelding 2 van 2
    • Remove the first 3mm screw with the Phillips #1 screwdriver.
    • Remove the next three 3mm screws.
  9. Toshiba Satellite L675D-S7016 Top Case Housing Removal: stap 9, afbeelding 1 van 2 Toshiba Satellite L675D-S7016 Top Case Housing Removal: stap 9, afbeelding 2 van 2
    • Lift the keyboard gently . Slide it forward towards the screen and speakers. This reveals the connection needed for the next step.
  10. Toshiba Satellite L675D-S7016 Top Case Housing Removal: stap 10, afbeelding 1 van 3 Toshiba Satellite L675D-S7016 Top Case Housing Removal: stap 10, afbeelding 2 van 3 Toshiba Satellite L675D-S7016 Top Case Housing Removal: stap 10, afbeelding 3 van 3
    • Use the pointed end of the Heavy-Duty Spudger and push the pins toward the screen, leaving them in this position.
    • Carefully slide the connector out of the port.
  11. Toshiba Satellite L675D-S7016 Top Case Housing Removal, Top Case Housing: stap 11, afbeelding 1 van 1
    • Remove the following screws with a Phillips #1 screwdriver.
    • Seventeen 5mm screws (recessed)
    • Three 2mm screws in the battery bay (flush-mounted)
    • Single 5mm screw does not need removal unless working on the screen
  12. Toshiba Satellite L675D-S7016 Top Case Housing Removal: stap 12, afbeelding 1 van 2 Toshiba Satellite L675D-S7016 Top Case Housing Removal: stap 12, afbeelding 2 van 2
    • Remove five 5mm screws with the screwdriver.
  13. Toshiba Satellite L675D-S7016 Top Case Housing Removal: stap 13, afbeelding 1 van 2 Toshiba Satellite L675D-S7016 Top Case Housing Removal: stap 13, afbeelding 2 van 2
    • Locate the trackpad connector.
    • Pull the ribbon from the connector.
  14. Toshiba Satellite L675D-S7016 Top Case Housing Removal: stap 14, afbeelding 1 van 2 Toshiba Satellite L675D-S7016 Top Case Housing Removal: stap 14, afbeelding 2 van 2
    • Pry under the top case housing along the perimeter with a plastic opening tool.
    • Be careful and gentle with this step, the clips you are releasing here are plastic and can be broken by violent prying.
Conclusie
Austin Bons
1.131 Reputatie
8 handleidingen geschreven
UC Davis, Team 2-2, Oliver Fall 2016 Lid van UC Davis, Team 2-2, Oliver Fall 2016
UCD-OLIVER-F16S2G2
5 Leden
10 handleidingen geschreven
Één opmerking
Great help this tutorial helped
Susan Scroggs - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 16
Altijd: 1,108
