Inleiding
If you find that your computer is responding slow, this guide will show you how to access and remove the RAM.
Wat je nodig hebt
Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
Using your fingers, spread the spring tabs holding the top stick of RAM in place.
Once the tabs are spread apart, the stick of RAM will pop up.
Remove the first stick of RAM by pulling out along the same angle the RAM stick springs up.
