Ga door naar hoofdinhoud
Toshiba Satellite L675D-S7016 RAM Replacement
Wat je nodig hebt
  1. Toshiba Satellite L675D-S7016 RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Power down the computer and unplug the power adapter.
  2. Toshiba Satellite L675D-S7016 RAM Replacement: stap 2, afbeelding 1 van 1
    • Flip the laptop upside down. Locate the two latches on both sides of the battery.
  3. Toshiba Satellite L675D-S7016 RAM Replacement: stap 3, afbeelding 1 van 3 Toshiba Satellite L675D-S7016 RAM Replacement: stap 3, afbeelding 2 van 3 Toshiba Satellite L675D-S7016 RAM Replacement: stap 3, afbeelding 3 van 3
    • Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
    • Simultaneously slide the latch on the left outwards while pulling the battery towards you.
    • Do not touch the metal connectors on the laptop and the battery.
  4. Toshiba Satellite L675D-S7016 RAM Replacement, Back Panel Removal: stap 4, afbeelding 1 van 1
    • Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
  5. Toshiba Satellite L675D-S7016 RAM Replacement: stap 5, afbeelding 1 van 2 Toshiba Satellite L675D-S7016 RAM Replacement: stap 5, afbeelding 2 van 2
    • Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
    • Work your way around the border of the panel, releasing the rest of the clips.
    • Once all clips are released, lift the cover up and pull towards you.
  6. Toshiba Satellite L675D-S7016 RAM Replacement, RAM: stap 6, afbeelding 1 van 3 Toshiba Satellite L675D-S7016 RAM Replacement, RAM: stap 6, afbeelding 2 van 3 Toshiba Satellite L675D-S7016 RAM Replacement, RAM: stap 6, afbeelding 3 van 3
    • Using your fingers, spread the spring tabs holding the top stick of RAM in place.
    • Once the tabs are spread apart, the stick of RAM will pop up.
    • Remove the first stick of RAM by pulling out along the same angle the RAM stick springs up.
  7. Toshiba Satellite L675D-S7016 RAM Replacement: stap 7, afbeelding 1 van 3 Toshiba Satellite L675D-S7016 RAM Replacement: stap 7, afbeelding 2 van 3 Toshiba Satellite L675D-S7016 RAM Replacement: stap 7, afbeelding 3 van 3
    • Repeat the same procedure to remove the second stick of RAM.
Conclusie
Austin Bons
1.131 Reputatie
8 handleidingen geschreven
UC Davis, Team 2-2, Oliver Fall 2016 Lid van UC Davis, Team 2-2, Oliver Fall 2016
UCD-OLIVER-F16S2G2
5 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 587
