Ga door naar hoofdinhoud
Toshiba Satellite L675D-S7016 Keyboard Replacement
Wat je nodig hebt
  1. Toshiba Satellite L675D-S7016 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Power down the computer and unplug the power adapter.
  2. Toshiba Satellite L675D-S7016 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Flip the laptop upside down. Locate the two latches on both sides of the battery.
  3. Toshiba Satellite L675D-S7016 Keyboard Replacement: stap 3, afbeelding 1 van 3 Toshiba Satellite L675D-S7016 Keyboard Replacement: stap 3, afbeelding 2 van 3 Toshiba Satellite L675D-S7016 Keyboard Replacement: stap 3, afbeelding 3 van 3
    • Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
    • Simultaneously slide the latch on the left outwards while pulling the battery towards you.
    • Do not touch the metal connectors on the laptop and the battery.
  4. Toshiba Satellite L675D-S7016 Keyboard Replacement, Keyboard: stap 4, afbeelding 1 van 3 Toshiba Satellite L675D-S7016 Keyboard Replacement, Keyboard: stap 4, afbeelding 2 van 3 Toshiba Satellite L675D-S7016 Keyboard Replacement, Keyboard: stap 4, afbeelding 3 van 3
    • Pry under the plastic strip, starting on the top right side of the key board with a Heavy Duty Spudger.
    • Once the first corner is raised, use your hand pulling upwards and release the rest of the strip.
  5. Toshiba Satellite L675D-S7016 Keyboard Replacement: stap 5, afbeelding 1 van 2 Toshiba Satellite L675D-S7016 Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Remove the first 3mm screw with the Phillips #1 screwdriver.
    • Remove the next three 3mm screws.
  6. Toshiba Satellite L675D-S7016 Keyboard Replacement: stap 6, afbeelding 1 van 2 Toshiba Satellite L675D-S7016 Keyboard Replacement: stap 6, afbeelding 2 van 2
    • Lift the keyboard gently . Slide it forward towards the screen and speakers. This reveals the connection needed for the next step.
  7. Toshiba Satellite L675D-S7016 Keyboard Replacement: stap 7, afbeelding 1 van 3 Toshiba Satellite L675D-S7016 Keyboard Replacement: stap 7, afbeelding 2 van 3 Toshiba Satellite L675D-S7016 Keyboard Replacement: stap 7, afbeelding 3 van 3
    • Use the pointed end of the Heavy-Duty Spudger and push the pins toward the screen, leaving them in this position.
    • Carefully slide the connector out of the port.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Austin Bons
1.131 Reputatie
8 handleidingen geschreven
UC Davis, Team 2-2, Oliver Fall 2016 Lid van UC Davis, Team 2-2, Oliver Fall 2016
UCD-OLIVER-F16S2G2
5 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 772
