Ga door naar hoofdinhoud
Toshiba Satellite L675D-S7016 Disk Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite L675D-S7016 Disk Drive Replacement, Back Panel Removal: stap 1, afbeelding 1 van 1
    • Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
  2. Toshiba Satellite L675D-S7016 Disk Drive Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite L675D-S7016 Disk Drive Replacement: stap 2, afbeelding 2 van 2
    • Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
    • Work your way around the border of the panel, releasing the rest of the clips.
    • Once all clips are released, lift the cover up and pull towards you.
  3. Toshiba Satellite L675D-S7016 Disk Drive Replacement, Disk Drive: stap 3, afbeelding 1 van 1
    • Remove the single 5mm Phillips #1 screw using the screwdriver.
  4. Toshiba Satellite L675D-S7016 Disk Drive Replacement: stap 4, afbeelding 1 van 2 Toshiba Satellite L675D-S7016 Disk Drive Replacement: stap 4, afbeelding 2 van 2
    • Push the exposed portion of the Disk Drive outwards.
    • The Disk Drive will begin sliding out of its slot. Remove Disk Drive from the laptop by hand.
  5. Toshiba Satellite L675D-S7016 Disk Drive Replacement: stap 5, afbeelding 1 van 2 Toshiba Satellite L675D-S7016 Disk Drive Replacement: stap 5, afbeelding 2 van 2
    • This step is only necessary if there is a disc stuck inside the drive! If you are replacing the drive and do not need to remove a disc, this can be skipped.
    • On the front of the Disk Drive, below the eject button, insert a pin or paperclip into the hole.
    • Push the pin into hole until the Disk Drive pops out.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Austin Bons
1.131 Reputatie
8 handleidingen geschreven
UC Davis, Team 2-2, Oliver Fall 2016 Lid van UC Davis, Team 2-2, Oliver Fall 2016
UCD-OLIVER-F16S2G2
5 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 9
Altijd: 342
