Ga door naar hoofdinhoud
Toshiba Satellite L675D-S7015 Disk Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite L675D-S7015 Disk Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the laptop on a scratch free surface, exposing underneath the laptop.
    • Identify the unlocking latches denoted by the red circles.
  2. Toshiba Satellite L675D-S7015 Disk Drive Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite L675D-S7015 Disk Drive Replacement: stap 2, afbeelding 2 van 2
    • Simply slide the latches outward to the unlocked position.
    • The latches should stay in the unlocked position. If not, hold them in the unlocked position.
    • With the latches in the unlocked position, slide the battery out, away from the laptop.
  3. Toshiba Satellite L675D-S7015 Disk Drive Replacement, Disk Drive: stap 3, afbeelding 1 van 2 Toshiba Satellite L675D-S7015 Disk Drive Replacement, Disk Drive: stap 3, afbeelding 2 van 2
    • Remove the the screw shown by the red circle.
    • Lift and remove the panel shown.
  4. Toshiba Satellite L675D-S7015 Disk Drive Replacement: stap 4, afbeelding 1 van 1
    • Remove the screw shown by the red circle.
    • Locate the small square that shows the back edge of the disk drive.
    • Push the drive in the direction shown until it cannot be pushed any further.
  5. Toshiba Satellite L675D-S7015 Disk Drive Replacement: stap 5, afbeelding 1 van 1
    • Pull the now revealed part of the disk drive in the direction shown until the disk drive is released.
Conclusie
Jared Smith
231 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 103
