Wat je nodig hebt
Locate the battery locks on the bottom of the laptop.
Slide the right lock outwards, until it locks into place.
Slide and hold the left lock outwards and hold it in place.
Using a #1 Phillips screwdriver, remove the 5.8 mm screw in the battery slot.
Remove stickers from four corners of laptop.
Remove screws underneath stickers.
Use plastic opening tool to pry the hinges off.
Remove the screen cover.
Unscrew the six screws on the bottom of the screen near the top of the hinges.
There is a large plastic cover surrounding where the keyboard was and covering the hinges. How did it come off??
