Ga door naar hoofdinhoud
Toshiba Satellite L655D-S5095 Keyboard Replacement
Wat je nodig hebt
  1. Toshiba Satellite L655D-S5095 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 3 Toshiba Satellite L655D-S5095 Keyboard Replacement, Battery: stap 1, afbeelding 2 van 3 Toshiba Satellite L655D-S5095 Keyboard Replacement, Battery: stap 1, afbeelding 3 van 3
    • Locate the battery locks on the bottom of the laptop.
    • Slide the right lock outwards, until it locks into place.
    • Slide and hold the left lock outwards and hold it in place.
  2. Toshiba Satellite L655D-S5095 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • While holding the lock in place, slide the battery out towards you.
  3. Toshiba Satellite L655D-S5095 Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 1
    • Using a #1 Phillips screwdriver, remove the 5.8 mm screw in the battery slot.
  4. Toshiba Satellite L655D-S5095 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Use a plastic opening tool to pry off the plastic panel above the keyboard.
  5. Toshiba Satellite L655D-S5095 Keyboard Replacement: stap 5, afbeelding 1 van 2 Toshiba Satellite L655D-S5095 Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Unscrew the four 3.7 mm screws at the top of the keyboard using a #1 Phillips screwdriver.
  6. Toshiba Satellite L655D-S5095 Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Slowly lift the keyboard out, up and towards the screen.
    • Do not try to remove the keyboard completely because it is still attached to the motherboard.
  7. Toshiba Satellite L655D-S5095 Keyboard Replacement: stap 7, afbeelding 1 van 1
    • Using a plastic opening tool, flip the ZIF connector up to release the ribbon and the keyboard.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Jerry Wakai
377 Reputatie
4 handleidingen geschreven
Cal Poly, Team 7-7, Maness Winter 2013 Lid van Cal Poly, Team 7-7, Maness Winter 2013
CPSU-MANESS-W13S7G7
5 Leden
6 handleidingen geschreven
2 opmerkingen
Nice little guide. The only thing I can really think to add would be on the last part for those of us who are super-paranoid about breaking something. If you could add a picture of what the ZIF connector looks like after it's opened would help some.
I appreciate the guide, thanks. :)
Christopher Tidwell - Antwoord
Ditto on all of it. I think I broke my ZIF connector !! Help!! 😔
salirizz67@gmail.com -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 4,908
