Inleiding
Replacing the hard drive in your laptop is a beginner level repair, which can easily be executed.
Onderdelen
Geen onderdelen nodig.
  1. Unscrew the two screws holding the panel over the hard drive using a Phillips screwdriver. The panel is located on the top right of the laptop's underside. Unscrew the two screws holding the panel over the hard drive using a Phillips screwdriver. The panel is located on the top right of the laptop's underside.
    • Unscrew the two screws holding the panel over the hard drive using a Phillips screwdriver. The panel is located on the top right of the laptop's underside.
  2. Remove the cover, firmly lifting from the indent. It is recommended that you leave the screws in the panel.
    • Remove the cover, firmly lifting from the indent. It is recommended that you leave the screws in the panel.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  4. Remove the screw located under the plastic tab. Remove the screw located under the plastic tab.
    • Remove the screw located under the plastic tab.
  5. Remove the hard drive by pulling the tab upwards and sliding the hard drive out. Remove the hard drive by pulling the tab upwards and sliding the hard drive out.
    • Remove the hard drive by pulling the tab upwards and sliding the hard drive out.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Jerry Wakai
335 Reputatie
4 handleidingen geschreven
Cal Poly, Team 7-7, Maness Winter 2013 Lid van Cal Poly, Team 7-7, Maness Winter 2013
CPSU-MANESS-W13S7G7
5 Leden
6 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 6
Afgelopen 30 Dagen: 37
Altijd: 2,656
