Ga door naar hoofdinhoud
Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement
Wat je nodig hebt
  1. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement, Chat Camera and Microphone Daughter Board: stap 1, afbeelding 1 van 3 Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement, Chat Camera and Microphone Daughter Board: stap 1, afbeelding 2 van 3 Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement, Chat Camera and Microphone Daughter Board: stap 1, afbeelding 3 van 3
    • Using a plastic opening tool, remove the four plastic stickers located on the four corners of the LCD screen assembly. These plastic stickers are covering screws.
    • Use a Phillips #1 screwdriver to remove the now uncovered 5.75mm screws and place them to the side.
  2. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: stap 2, afbeelding 2 van 2
    • With a plastic soft pry tool, open up the laptop display assembly by methodically prying from left to right. Be careful to not damage any internal circuitry.
    • Do not attempt to pry apart the bottom, the LCD assembly never gets fully disassembled in this tutorial.
  3. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: stap 3, afbeelding 2 van 2
    • Remove the 2 pieces of black tape using a sharp tool to free the camera board, note that the camera board is still connected to a cable.
  4. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: stap 4, afbeelding 1 van 2 Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: stap 4, afbeelding 2 van 2
    • Carefully disconnect the camera board from the laptop. We used tweezers.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Robby
52 Reputatie
1 Handleiding geschreven
Cal Poly, Team 7-7, Maness Winter 2013 Lid van Cal Poly, Team 7-7, Maness Winter 2013
CPSU-MANESS-W13S7G7
5 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 2,575
