Inleiding
This guide will help you replace your CD drive if you've determined that it is no longer working.
Wat je nodig hebt
Unscrew the three 4.6 mm screws holding the panel using a #1 size Phillips head screwdriver. The panel is centered on the bottom of the laptop.
Één andere persoon heeft deze handleiding voltooid.
