Ga door naar hoofdinhoud
Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink
Wat je nodig hebt
  1. Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Battery: stap 1, afbeelding 1 van 3 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Battery: stap 1, afbeelding 2 van 3 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Battery: stap 1, afbeelding 3 van 3
    • Make sure you turn the laptop off first.
    • Close the laptop lid and flip it over so that Toshiba logo is facing down.
  2. Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: stap 2, afbeelding 1 van 2 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: stap 2, afbeelding 2 van 2
    • Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
  3. Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: stap 3, afbeelding 1 van 3 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: stap 3, afbeelding 2 van 3 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: stap 3, afbeelding 3 van 3
    • Once the screws are removed, slide the battery pack out of the computer.
  4. Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Back Panel: stap 4, afbeelding 1 van 3 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Back Panel: stap 4, afbeelding 2 van 3 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Back Panel: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Anti-Static Wrist Strap
    $7.95
    Koop
    • Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
    • Use the plastic opening tool to remove the back cover from the laptop.
    • Be aware that static discharge can cause damage to sensitive electrical components within the computer. To avoid this you can wear an anti-static wrist strap.
  5. Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Cooling Fan with Heat Sink: stap 5, afbeelding 1 van 3 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Cooling Fan with Heat Sink: stap 5, afbeelding 2 van 3 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Cooling Fan with Heat Sink: stap 5, afbeelding 3 van 3
    • The ribbon and wire must be moved out of the way of the fan.
    • Using a black tweezer tool, lift the tab holding the ribbon in place and then gently pull it out.
    • Using the same tweezer tool, again lift the tab holding the wires in place and gently pull them out.
  6. Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: stap 6, afbeelding 1 van 2 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: stap 6, afbeelding 2 van 2
    • Unscrew the two 3mm Phillips head screws on each fan using the Phillips #00 screwdriver.
  7. Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: stap 7, afbeelding 1 van 3 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: stap 7, afbeelding 2 van 3 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: stap 7, afbeelding 3 van 3
    • Unscrew the four, 3mm Phillips head screws holding the last piece to the laptop using a Phillips #00 screwdriver.
    • Gently pull the cooling fan with heat sink off the laptop and set aside.
Conclusie
Noelle Dulude
480 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S3-G3, Peak Spring 2018 Lid van UMass Dartmouth, Team S3-G3, Peak Spring 2018
UMASSD-PEAK-S18S3G3
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 544
