Inleiding
This guide will help you remove the back panel of your device. No special skills are required, but you do need to know how to use a Phillips #00 screwdriver.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:Anti-Static Wrist Strap$7.95
Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
Use the plastic opening tool to remove the back cover from the laptop.
Bijna klaar!
Conclusie
