Ga door naar hoofdinhoud
Toshiba Satellite L55W-C5256 Speaker Replacement
Wat je nodig hebt
  1. Toshiba Satellite L55W-C5256 Speaker Replacement, Battery: stap 1, afbeelding 1 van 1
    • Before beginning this repair, power off your device and unplug all cables and accessory devices.
    • Flip the laptop over so that the model numbers are facing the ceiling.
  2. Toshiba Satellite L55W-C5256 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the 10 screws that secure the back cover to the device.
  3. Toshiba Satellite L55W-C5256 Speaker Replacement: stap 3, afbeelding 1 van 1
    • Gently use an iFixit opening tool to separate the back cover from the laptop. Go around all edges until plastic clips are completely free.
    • Ensure all plastic clips have been freed. Attempting to forcefully remove the back cover could result in damage to your device.
  4. Toshiba Satellite L55W-C5256 Speaker Replacement: stap 4, afbeelding 1 van 1
    • Before touching any component inside your device, ensure you are properly grounded with an anti-static band.
    • Disconnect the battery connector cable from the motherboard.
  5. Toshiba Satellite L55W-C5256 Speaker Replacement: stap 5, afbeelding 1 van 1
    • Using a Phillip's #00 screwdriver, remove the four 7.0 mm screws that secure the battery to the motherboard.
  6. Toshiba Satellite L55W-C5256 Speaker Replacement: stap 6, afbeelding 1 van 1
    • Lift the battery from the motherboard.
  7. Toshiba Satellite L55W-C5256 Speaker Replacement, CPU Heatsink: stap 7, afbeelding 1 van 1
    • Using a Phillips #00 screw driver, remove the four 7.0 mm screws that secure the heat sink to the CPU.
  8. Toshiba Satellite L55W-C5256 Speaker Replacement: stap 8, afbeelding 1 van 1
    • Using a Phillips #00 screw driver, remove the two 7.0 mm screws that secure the heat sink fan to the motherboard.
  9. Toshiba Satellite L55W-C5256 Speaker Replacement: stap 9, afbeelding 1 van 3 Toshiba Satellite L55W-C5256 Speaker Replacement: stap 9, afbeelding 2 van 3 Toshiba Satellite L55W-C5256 Speaker Replacement: stap 9, afbeelding 3 van 3
    • Before you touch any component inside your device, ensure you are properly grounded with an anti-static band.
    • Gently lift the heat sink from the motherboard, making sure not to apply much tension to the connector cable.
    • Using your thumb and forefinger, gently unplug the connector cable from the motherboard.
    • Lift the heat sink from the motherboard.
    • If you need to replace the heat sink, check out this thermal paste guide that will walk you through the steps necessary to replace the thermal compound.
  10. Toshiba Satellite L55W-C5256 Speaker Replacement, Speakers: stap 10, afbeelding 1 van 2 Toshiba Satellite L55W-C5256 Speaker Replacement, Speakers: stap 10, afbeelding 2 van 2
    • Using a Phillips #00 screw driver, remove the two 7.0 mm screws that secure the left speaker to the motherboard.
    • Using a Phillips #00 screw driver, remove the two 7.0 mm screws that secure the right speaker to the motherboard.
  11. Toshiba Satellite L55W-C5256 Speaker Replacement: stap 11, afbeelding 1 van 2 Toshiba Satellite L55W-C5256 Speaker Replacement: stap 11, afbeelding 2 van 2
    • Before touching any component inside your device, ensure you are properly grounded with a static band.
    • Gently unplug the speaker connector cable from the motherboard.
  12. Toshiba Satellite L55W-C5256 Speaker Replacement: stap 12, afbeelding 1 van 1
    • Lift speakers from motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jennifer
777 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 154
