Inleiding
This guide will instruct you on how to safely remove and replace the RAM in your Toshiba Satellite L55W-C5256. You may need to do this if:
- Your device’s RAM has failed, and needs to be replaced
- You are upgrading your device’s RAM
Before beginning this replacement guide, it is recommended that you use an anti-static work mat and that you ground yourself using an anti-static wrist strap. This helps to protect your device from damage caused by static discharge. If you do not have these materials, you can find an anti-static wrist strap here, and an anti-static work mat here. To learn how to properly use an anti-static wrist strap and an anti-static work mat (recommended), see the guide found here.
Wat je nodig hebt
Using your forefinger, gently pull on the left bracket that secures the RAM to the motherboard.
Using your forefinger, gently pull on the right bracket that secures the RAM to the motherboard.
Lift the RAM stick from the motherboard.
