Ga door naar hoofdinhoud
Toshiba Satellite L55W-C5256 Hard Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite L55W-C5256 Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Before beginning this repair, power off your device and unplug all cables and accessory devices.
    • Flip the laptop over so that the model numbers are facing the ceiling.
  2. Toshiba Satellite L55W-C5256 Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the 10 screws that secure the back cover to the device.
  3. Toshiba Satellite L55W-C5256 Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Gently use an iFixit opening tool to separate the back cover from the laptop. Go around all edges until plastic clips are completely free.
    • Ensure all plastic clips have been freed. Attempting to forcefully remove the back cover could result in damage to your device.
  4. Toshiba Satellite L55W-C5256 Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • Before touching any component inside your device, ensure you are properly grounded with an anti-static band.
    • Disconnect the battery connector cable from the motherboard.
  5. Toshiba Satellite L55W-C5256 Hard Drive Replacement: stap 5, afbeelding 1 van 1
    • Using a Phillip's #00 screwdriver, remove the four 7.0 mm screws that secure the battery to the motherboard.
  6. Toshiba Satellite L55W-C5256 Hard Drive Replacement: stap 6, afbeelding 1 van 1
    • Lift the battery from the motherboard.
  7. Toshiba Satellite L55W-C5256 Hard Drive Replacement, Hard Drive: stap 7, afbeelding 1 van 2 Toshiba Satellite L55W-C5256 Hard Drive Replacement, Hard Drive: stap 7, afbeelding 2 van 2
    • Flip the white part of the hard drive cable connector up.
    • Gently pull the cable out.
  8. Toshiba Satellite L55W-C5256 Hard Drive Replacement: stap 8, afbeelding 1 van 1
    • Lift the hard drive from the device.
  9. Toshiba Satellite L55W-C5256 Hard Drive Replacement: stap 9, afbeelding 1 van 2 Toshiba Satellite L55W-C5256 Hard Drive Replacement: stap 9, afbeelding 2 van 2
    • After removing the hard drive, remove the connection cable.
    • Set the connection cable aside for use with your replacement hard drive.
  10. Toshiba Satellite L55W-C5256 Hard Drive Replacement: stap 10, afbeelding 1 van 1
    • Remove the protective blue rubber caging from the hard drive.
    • Be sure not to damage the blue rubber caging during removal. This protective caging prevents your hard drive from moving freely inside your device, and will be needed for reassembly.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Jennifer
777 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 19
Altijd: 733
