Ga door naar hoofdinhoud
Toshiba Satellite L55W-C5256 Battery Replacement
Wat je nodig hebt
  1. Toshiba Satellite L55W-C5256 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Before beginning this repair, power off your device and unplug all cables and accessory devices.
    • Flip the laptop over so that the model numbers are facing the ceiling.
  2. Toshiba Satellite L55W-C5256 Battery Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the 10 screws that secure the back cover to the device.
  3. Toshiba Satellite L55W-C5256 Battery Replacement: stap 3, afbeelding 1 van 1
    • Gently use an iFixit opening tool to separate the back cover from the laptop. Go around all edges until plastic clips are completely free.
    • Ensure all plastic clips have been freed. Attempting to forcefully remove the back cover could result in damage to your device.
  4. Toshiba Satellite L55W-C5256 Battery Replacement: stap 4, afbeelding 1 van 1
    • Before touching any component inside your device, ensure you are properly grounded with an anti-static band.
    • Disconnect the battery connector cable from the motherboard.
  5. Toshiba Satellite L55W-C5256 Battery Replacement: stap 5, afbeelding 1 van 1
    • Using a Phillip's #00 screwdriver, remove the four 7.0 mm screws that secure the battery to the motherboard.
  6. Toshiba Satellite L55W-C5256 Battery Replacement: stap 6, afbeelding 1 van 1
    • Lift the battery from the motherboard.
Conclusie
Jennifer
777 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 823
