Ga door naar hoofdinhoud
Toshiba Satellite L505D-GS6000 Disk Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite L505D-GS6000 Disk Drive Replacement, Battery: stap 1, afbeelding 1 van 2 Toshiba Satellite L505D-GS6000 Disk Drive Replacement, Battery: stap 1, afbeelding 2 van 2
    • Shut down the computer and disconnect all cables.
    • Flip the computer over so that the bottom is facing up.
    • Slide right switch above the battery so that it is in the rightwards position.
  2. Toshiba Satellite L505D-GS6000 Disk Drive Replacement: stap 2, afbeelding 1 van 1
    • Push and hold the left-most switch in the leftward position.
    • While holding the left switch in position, lift up on the battery from the groove in the casing and remove.
  3. Toshiba Satellite L505D-GS6000 Disk Drive Replacement, Disk Drive: stap 3, afbeelding 1 van 1
    • Remove the M2 5x6 mm screw pointed out in the picture using the Phillips #0 screwdriver.
    • You do not need to remove anything else in order to take out the disk drive.
  4. Toshiba Satellite L505D-GS6000 Disk Drive Replacement: stap 4, afbeelding 1 van 1
    • Gently slide the disk drive out to the right until it is removed from the computer.
    • If the disk drive doesn’t easily slide out then there is possible damage on the inside of the laptop.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Adam Dellicker
539 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S4-G2, Covino Spring 2018 Lid van UMass Dartmouth, Team S4-G2, Covino Spring 2018
UMASSD-COVINO-S18S4G2
2 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 10
Altijd: 357
