Ga door naar hoofdinhoud
Toshiba Satellite L505 Laptop Speakers Replacement
Wat je nodig hebt
  1. Toshiba Satellite L505 Laptop Speakers Replacement, Keyboard: stap 1, afbeelding 1 van 3 Toshiba Satellite L505 Laptop Speakers Replacement, Keyboard: stap 1, afbeelding 2 van 3 Toshiba Satellite L505 Laptop Speakers Replacement, Keyboard: stap 1, afbeelding 3 van 3
    • Open the laptop and locate the plastic strip just above the keyboard.
    • With care, slide the prying tool into an end and lift it up until you hear an audible click, meaning it has separated.
    • Slowly slide a finger or the prying tool under and follow the strip to the opposite end, completely detaching the strip.
  2. Toshiba Satellite L505 Laptop Speakers Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite L505 Laptop Speakers Replacement: stap 2, afbeelding 2 van 2
    • Remove the four screws using the Phillips #1 screwdriver.
  3. Toshiba Satellite L505 Laptop Speakers Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite L505 Laptop Speakers Replacement: stap 3, afbeelding 2 van 2
    • Gently push the clip back as you lift the top of the keyboard towards you.
    • There is a cable connecting the keyboard to the motherboard so do not lift the keyboard all the way out yet.
  4. Toshiba Satellite L505 Laptop Speakers Replacement: stap 4, afbeelding 1 van 3 Toshiba Satellite L505 Laptop Speakers Replacement: stap 4, afbeelding 2 van 3 Toshiba Satellite L505 Laptop Speakers Replacement: stap 4, afbeelding 3 van 3
    • Gently disconnect the connector strip by pushing the white clips forward.
    • Carefully pull the strip out of its port.
    • Remove the keyboard from the device.
  5. Toshiba Satellite L505 Laptop Speakers Replacement, Optical Drive: stap 5, afbeelding 1 van 2 Toshiba Satellite L505 Laptop Speakers Replacement, Optical Drive: stap 5, afbeelding 2 van 2
    • Turn the laptop upside down.
    • Remove the screw labeled F4 using the Phillips #1 screwdriver.
    • There are 2 screws labeled F4, the correct screw is the one closer to the hard drive.
  6. Toshiba Satellite L505 Laptop Speakers Replacement: stap 6, afbeelding 1 van 2 Toshiba Satellite L505 Laptop Speakers Replacement: stap 6, afbeelding 2 van 2
    • Gently slide the optical drive out of the device.
  7. Toshiba Satellite L505 Laptop Speakers Replacement, Battery: stap 7, afbeelding 1 van 1
    • Turn your laptop upside down, at the bottom of the laptop, slide the right sliding lock to the unlocked position.
    • Slide the left sliding lock to the left and hold it. Using your fingers lift the battery out.
  8. Toshiba Satellite L505 Laptop Speakers Replacement, Palm Rest Assembly: stap 8, afbeelding 1 van 3 Toshiba Satellite L505 Laptop Speakers Replacement, Palm Rest Assembly: stap 8, afbeelding 2 van 3 Toshiba Satellite L505 Laptop Speakers Replacement, Palm Rest Assembly: stap 8, afbeelding 3 van 3
    • Unscrew all of the screws marked on the underside of the laptop.
    • Remove the screw marked in the second photo by lifting up the lid and unscrewing using a Phillips #1 screwdriver.
    • Remove the three flat screws in the port where the Optical drive is housed in.
  9. Toshiba Satellite L505 Laptop Speakers Replacement: stap 9, afbeelding 1 van 2 Toshiba Satellite L505 Laptop Speakers Replacement: stap 9, afbeelding 2 van 2
    • Remove the keyboard and once that has been done, remove the screw marked "16."
    • Disconnect all of the cables with a blue circle.
  10. Toshiba Satellite L505 Laptop Speakers Replacement: stap 10, afbeelding 1 van 3 Toshiba Satellite L505 Laptop Speakers Replacement: stap 10, afbeelding 2 van 3 Toshiba Satellite L505 Laptop Speakers Replacement: stap 10, afbeelding 3 van 3
    • Using the opening tool, carefully go around the edge and loosen the palm-rest assembly, until you can comfortably and easily lift it off.
  11. Toshiba Satellite L505 Laptop Speakers Replacement, Speakers: stap 11, afbeelding 1 van 1
    • Remove the Palm rest assembly and flip it over.
    • Locate the 2 speakers.
  12. Toshiba Satellite L505 Laptop Speakers Replacement: stap 12, afbeelding 1 van 1
    • Remove the three screws.
  13. Toshiba Satellite L505 Laptop Speakers Replacement: stap 13, afbeelding 1 van 1
    • Follow the red and white wires until they join into a plug and disconnect for easy removal of the speakers.
Conclusie
Matias
1.013 Reputatie
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 12
Altijd: 629
