Inleiding
The wifi card enables the computer to be compatible with wifi. If the card is malfunctioning, the computer will not receive a signal from any wifi sources. This guide shows how to remove the wifi card so it can be replaced.
Wat je nodig hebt
Unscrew the Phillips #1 4mm screw from the middle panel using a Phillips #1 screwdriver.
4 andere personen hebben deze handleiding voltooid.
