Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Use the flat edge of the plastic opening tool to pry open the narrow plastic strip above the keyboard.
Remove the three 3mm screws with a Phillips#00 Screwdriver.
Lift the keyboard away from the top side of the laptop.
Disconnect the keyboard cable that is still attached to the keyboard.
Unlatch the fastener.
Using your hands, pull the keyboard connector out, not up.
Één andere persoon heeft deze handleiding voltooid.
