Inleiding
This guide is useful for replacing a broken cooling fan on your laptop. The fan is designed to draw in cool air to prevent the laptop from overheating. In this replacement guide, you will remove the lower cover to access the fan.
Note: Before starting any removal or installation, remember to turn off the device and to remove it from the power source.
Wat je nodig hebt
Use the flat edge of the plastic opening tool to pry open the narrow plastic strip above the keyboard.
Flip the laptop over to access the battery.
Remove the battery by sliding fingers away from each other and lifting up the tab at the same time.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
I've taken my Toshiba L455 apart a few times from watching a few different You Tube videos. I WISH I would've seen THIS site & demonstration then! It makes it SO MUCH easier by actually showing each & ALL of the screws that need to come out,It tells you in GREAT detail step by step of everything you need to do so that nothing's ruined in the process! In the videos like when it comes to removing the keyboard/ribbon for it,you can't see what they're doing when removing the ribbon,which was my hardest part! I actually had it all put back together to learn it wasn't put back together right(since I wasn't exactly sure how it came off!) After 3 times,I FINALLY figured it out,by myself! So even this 1 doesn't say that the white clip that comes out 2 release the ribbon goes back UNDER the ribbon when putting it back! Cuz mine came out fast so I missed how it was even in there. Hopefully this helps someone since I SO wished I had this! Lol!
