Ga door naar hoofdinhoud
Toshiba Satellite L455-S5046 The Fan Replacement
Wat je nodig hebt
  1. Toshiba Satellite L455-S5046 The Fan Replacement, Battery: stap 1, afbeelding 1 van 2 Toshiba Satellite L455-S5046 The Fan Replacement, Battery: stap 1, afbeelding 2 van 2
    • Find the battery on the back of the computer. Slide both tabs outward towards the side of the laptop and the battery will come loose.
    • Insert your finger under the middle tab and lift the battery out.
  2. Toshiba Satellite L455-S5046 The Fan Replacement, Fan: stap 2, afbeelding 1 van 1
    • Start on the back and unscrew the 12 Phillips #0 11-mm screws holding the back cover down.
  3. Toshiba Satellite L455-S5046 The Fan Replacement: stap 3, afbeelding 1 van 1
    • Pop off the hard drive cover, and then unscrew the four 11-mm Phillips #0 screws.
  4. Toshiba Satellite L455-S5046 The Fan Replacement: stap 4, afbeelding 1 van 2 Toshiba Satellite L455-S5046 The Fan Replacement: stap 4, afbeelding 2 van 2
    • Flip the laptop over. Remove the keyboard as instructed in the keyboard replacement guide.
    • Gently remove the connector visible in the upper right hand corner of the laptop by pulling to the right.
    • Remove the cover slowly. There will be two other connectors on the underside that can be removed by pulling gently.
  5. Toshiba Satellite L455-S5046 The Fan Replacement: stap 5, afbeelding 1 van 2 Toshiba Satellite L455-S5046 The Fan Replacement: stap 5, afbeelding 2 van 2
    • Remove the connector between the fan and the laptop by pulling gently to the left.
    • Remove the two indicated 11-mm Phillips #0 screws.
  6. Toshiba Satellite L455-S5046 The Fan Replacement: stap 6, afbeelding 1 van 1
    • Now gently lift the fan and pull out.
Conclusie
Daryl Spurgeon
610 Reputatie
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 263
