Ga door naar hoofdinhoud
Toshiba Satellite L455-S5046 Hard-drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite L455-S5046 Hard-drive Replacement, Battery: stap 1, afbeelding 1 van 2 Toshiba Satellite L455-S5046 Hard-drive Replacement, Battery: stap 1, afbeelding 2 van 2
    • Find the battery on the back of the computer. Slide both tabs outward towards the side of the laptop and the battery will come loose.
    • Insert your finger under the middle tab and lift the battery out.
  2. Toshiba Satellite L455-S5046 Hard-drive Replacement, Hard-drive: stap 2, afbeelding 1 van 1
    • Locate the hard drive in the upper right corner on the back of the computer.
    • Unscrew the 2 Phillips #0 7-mm screws holding the cover in place and remove the cover.
  3. Toshiba Satellite L455-S5046 Hard-drive Replacement: stap 3, afbeelding 1 van 1
    • Once the cover is off, the hard drive will be exposed, carefully pull it out to the right.
Conclusie
Daryl Spurgeon
610 Reputatie
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 287
