Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Make sure the battery lock switch is switched to the unlocked position.
The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
Remove the 5 Phillips screws holding the panel in place.
Use a finger to remove the panel by lifting up on the provided removal tab.
Remove the black and the white antenna wires attached to the wireless card.
Using a plastic removal tool, gently pop the connections apart.
Remove the screws holding the wireless card in place.
Two 3.6 mm Phillips screws.
The wireless card will automatically pop up allowing for easy removal.
