Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Make sure the battery lock switch is switched to the unlocked position.
The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
Remove the two screws holding the hard drive panel down.
Use a finger to lift up on the tab and remove the panel.
Remove the screw that holds in place the optical drive.
One 4.6 mm Phillips screw.
Locate the small rectangular hole and insert the spudger.
Gently slide the metal flange to the right to dislodge the optical drive.
Pull the optical drive to remove it from the computer body.
