Ga door naar hoofdinhoud
Toshiba Satellite L45-S7423 Optical Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite L45-S7423 Optical Drive Replacement, Battery: stap 1, afbeelding 1 van 3 Toshiba Satellite L45-S7423 Optical Drive Replacement, Battery: stap 1, afbeelding 2 van 3 Toshiba Satellite L45-S7423 Optical Drive Replacement, Battery: stap 1, afbeelding 3 van 3
    • Make sure the battery lock switch is switched to the unlocked position.
    • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
  2. Toshiba Satellite L45-S7423 Optical Drive Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite L45-S7423 Optical Drive Replacement: stap 2, afbeelding 2 van 2
    • Slide the battery release switch to the left.
    • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  3. Toshiba Satellite L45-S7423 Optical Drive Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite L45-S7423 Optical Drive Replacement: stap 3, afbeelding 2 van 2
    • Using a finger, lift up the battery.
    • The battery release switch must be held in place.
  4. Toshiba Satellite L45-S7423 Optical Drive Replacement, Optical Drive: stap 4, afbeelding 1 van 3 Toshiba Satellite L45-S7423 Optical Drive Replacement, Optical Drive: stap 4, afbeelding 2 van 3 Toshiba Satellite L45-S7423 Optical Drive Replacement, Optical Drive: stap 4, afbeelding 3 van 3
    • Remove the two screws holding the hard drive panel down.
    • These screw are permanently fastened to the panel; they are designed to be removed only partially.
  5. Toshiba Satellite L45-S7423 Optical Drive Replacement: stap 5, afbeelding 1 van 1
    • Use a finger to lift up on the tab and remove the panel.
  6. Toshiba Satellite L45-S7423 Optical Drive Replacement: stap 6, afbeelding 1 van 2 Toshiba Satellite L45-S7423 Optical Drive Replacement: stap 6, afbeelding 2 van 2
    • Remove the screw that holds in place the optical drive.
    • One 4.6 mm Phillips screw.
  7. Toshiba Satellite L45-S7423 Optical Drive Replacement: stap 7, afbeelding 1 van 2 Toshiba Satellite L45-S7423 Optical Drive Replacement: stap 7, afbeelding 2 van 2
    • Locate the small rectangular hole and insert the spudger.
    • Gently slide the metal flange to the right to dislodge the optical drive.
  8. Toshiba Satellite L45-S7423 Optical Drive Replacement: stap 8, afbeelding 1 van 1
    • The optical drive will become partially exposed.
  9. Toshiba Satellite L45-S7423 Optical Drive Replacement: stap 9, afbeelding 1 van 2 Toshiba Satellite L45-S7423 Optical Drive Replacement: stap 9, afbeelding 2 van 2
    • Pull the optical drive to remove it from the computer body.
Conclusie
Stephen Sippel
194 Reputatie
9 handleidingen geschreven
Cal Poly, Team 21-54, Johann Spring 2013 Lid van Cal Poly, Team 21-54, Johann Spring 2013
CPSU-JOHANN-S13S21G54
4 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 885
