Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
The LCD display can be easily separated from the laptop body to allow for replacement if it is damaged or functioning improperly.
Wat je nodig hebt
Make sure the battery lock switch is switched to the unlocked position.
The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
Remove the Phillips screw holding the panel in place and then use a finger to remove the panel.
3 andere personen hebben deze handleiding voltooid.
