Ga door naar hoofdinhoud
Toshiba Satellite L45-S7423 LCD Display Replacement
Wat je nodig hebt
  1. Toshiba Satellite L45-S7423 LCD Display Replacement, Battery: stap 1, afbeelding 1 van 3 Toshiba Satellite L45-S7423 LCD Display Replacement, Battery: stap 1, afbeelding 2 van 3 Toshiba Satellite L45-S7423 LCD Display Replacement, Battery: stap 1, afbeelding 3 van 3
    • Make sure the battery lock switch is switched to the unlocked position.
    • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
  2. Toshiba Satellite L45-S7423 LCD Display Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite L45-S7423 LCD Display Replacement: stap 2, afbeelding 2 van 2
    • Slide the battery release switch to the left.
    • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  3. Toshiba Satellite L45-S7423 LCD Display Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite L45-S7423 LCD Display Replacement: stap 3, afbeelding 2 van 2
    • Using a finger, lift up the battery.
    • The battery release switch must be held in place.
  4. Toshiba Satellite L45-S7423 LCD Display Replacement, Bottom Access Panel: stap 4, afbeelding 1 van 3 Toshiba Satellite L45-S7423 LCD Display Replacement, Bottom Access Panel: stap 4, afbeelding 2 van 3 Toshiba Satellite L45-S7423 LCD Display Replacement, Bottom Access Panel: stap 4, afbeelding 3 van 3
    • Remove the 5 Phillips screws holding the panel in place.
    • These screws are permanently fastened to the panel; they are designed to be removed only partially to avoid loss.
  5. Toshiba Satellite L45-S7423 LCD Display Replacement: stap 5, afbeelding 1 van 3 Toshiba Satellite L45-S7423 LCD Display Replacement: stap 5, afbeelding 2 van 3 Toshiba Satellite L45-S7423 LCD Display Replacement: stap 5, afbeelding 3 van 3
    • Use a finger to remove the panel by lifting up on the provided removal tab.
  6. Toshiba Satellite L45-S7423 LCD Display Replacement, LCD Display: stap 6, afbeelding 1 van 3 Toshiba Satellite L45-S7423 LCD Display Replacement, LCD Display: stap 6, afbeelding 2 van 3 Toshiba Satellite L45-S7423 LCD Display Replacement, LCD Display: stap 6, afbeelding 3 van 3
    • Remove the Phillips screw holding the panel in place and then use a finger to remove the panel.
    • This screw is not designed to be completely removed, it is permanently fastened to the panel to avoid loss.
  7. Toshiba Satellite L45-S7423 LCD Display Replacement: stap 7, afbeelding 1 van 3 Toshiba Satellite L45-S7423 LCD Display Replacement: stap 7, afbeelding 2 van 3 Toshiba Satellite L45-S7423 LCD Display Replacement: stap 7, afbeelding 3 van 3
    • With the aid of a plastic removal, disconnect the two wires attached to the wireless card.
  8. Toshiba Satellite L45-S7423 LCD Display Replacement: stap 8, afbeelding 1 van 1
    • Remove the yellow tape holding the black and the white wires in place.
  9. Toshiba Satellite L45-S7423 LCD Display Replacement: stap 9, afbeelding 1 van 3 Toshiba Satellite L45-S7423 LCD Display Replacement: stap 9, afbeelding 2 van 3 Toshiba Satellite L45-S7423 LCD Display Replacement: stap 9, afbeelding 3 van 3
    • Unwind the wires from the plastic tabs holding the wires in place.
  10. Toshiba Satellite L45-S7423 LCD Display Replacement: stap 10, afbeelding 1 van 2 Toshiba Satellite L45-S7423 LCD Display Replacement: stap 10, afbeelding 2 van 2
    • Remove the screw holding the ground cable in place.
    • One 4.5 mm Phillips screw.
  11. Toshiba Satellite L45-S7423 LCD Display Replacement: stap 11, afbeelding 1 van 2 Toshiba Satellite L45-S7423 LCD Display Replacement: stap 11, afbeelding 2 van 2
    • Disconnect the video cable connecting the display to the base of the laptop.
  12. Toshiba Satellite L45-S7423 LCD Display Replacement: stap 12, afbeelding 1 van 3 Toshiba Satellite L45-S7423 LCD Display Replacement: stap 12, afbeelding 2 van 3 Toshiba Satellite L45-S7423 LCD Display Replacement: stap 12, afbeelding 3 van 3
    • Pop off the laptop's hinge covers using a spudger tool.
    • Only a small amount of force is required. Excessive force may permanently damage the hinge covers.
  13. Toshiba Satellite L45-S7423 LCD Display Replacement: stap 13, afbeelding 1 van 2 Toshiba Satellite L45-S7423 LCD Display Replacement: stap 13, afbeelding 2 van 2
    • Remove the two screws on the back side of the laptop holding the LCD display in place.
    • Two 8.5 mm Phillips screws.
  14. Toshiba Satellite L45-S7423 LCD Display Replacement: stap 14, afbeelding 1 van 2 Toshiba Satellite L45-S7423 LCD Display Replacement: stap 14, afbeelding 2 van 2
    • Remove the final two screws on the bottom side of the laptop holding the LCD display in place.
  15. Toshiba Satellite L45-S7423 LCD Display Replacement: stap 15, afbeelding 1 van 3 Toshiba Satellite L45-S7423 LCD Display Replacement: stap 15, afbeelding 2 van 3 Toshiba Satellite L45-S7423 LCD Display Replacement: stap 15, afbeelding 3 van 3
    • Carefully pull apart the LCD display from the base by pulling vertically upwards on the display.
    • Be careful as you remove the display not to pull too hard on the cables as they pass through the opening.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Stephen Sippel
194 Reputatie
9 handleidingen geschreven
Cal Poly, Team 21-54, Johann Spring 2013 Lid van Cal Poly, Team 21-54, Johann Spring 2013
CPSU-JOHANN-S13S21G54
4 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 15
Altijd: 1,890
