Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Make sure the battery lock switch is switched to the unlocked position.
The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
Remove the 5 Phillips screws holding the panel in place.
Use a finger to remove the panel by lifting up on the provided removal tab.
Remove the two screws holding the keyboard in place.
Two 5.7 mm Phillips screws.
There are three tabs holding the keyboard in place.
They are located under the ESC, F8, and DEL keys.
Expose the tabs by pressing down on adjacent keys.
While you press down the ESC key, push the tab with the spudger to release that side of the keyboard.
Use a finger to prevent the keyboard from locking back in place.
Repeat the previous step for the tabs under the F8 and DEL keys.
Pick up the keyboard. This exposes a cable that connects the keyboard to the laptop.
Gently unplug the ribbon cable connecting the keyboard to the laptop by pulling horizontally.
3 andere personen hebben deze handleiding voltooid.
