Ga door naar hoofdinhoud
Toshiba Satellite L35-S2174 Screen Replacement
Wat je nodig hebt
  1. Toshiba Satellite L35-S2174 Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the laptop off to prevent the possibility of electric shock or damage to the computer.
    • Flip the laptop so that the bottom is facing upwards.
  2. Toshiba Satellite L35-S2174 Screen Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite L35-S2174 Screen Replacement: stap 2, afbeelding 2 van 2
    • Slide the battery lock switch to the left.
  3. Toshiba Satellite L35-S2174 Screen Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite L35-S2174 Screen Replacement: stap 3, afbeelding 2 van 2
    • Pull the sliding switch to the right and continue to hold it in this position.
  4. Toshiba Satellite L35-S2174 Screen Replacement: stap 4, afbeelding 1 van 1
    • While holding the switch, slide the battery away from you.
    • You do not need to hold the switch when putting the battery back into the laptop.
  5. Toshiba Satellite L35-S2174 Screen Replacement, Keyboard: stap 5, afbeelding 1 van 2 Toshiba Satellite L35-S2174 Screen Replacement, Keyboard: stap 5, afbeelding 2 van 2
    • Remove the two circled 4mm screws with a J1 screwdriver.
  6. Toshiba Satellite L35-S2174 Screen Replacement: stap 6, afbeelding 1 van 2 Toshiba Satellite L35-S2174 Screen Replacement: stap 6, afbeelding 2 van 2
    • Remove the two circled 5mm screws with a J1 screwdriver.
  7. Toshiba Satellite L35-S2174 Screen Replacement: stap 7, afbeelding 1 van 2 Toshiba Satellite L35-S2174 Screen Replacement: stap 7, afbeelding 2 van 2
    • Use a spudger to pry up the plastic panel between the keyboard the screen.
    • Repeat on opposite side of laptop.
    • The panel may be difficult to remove.
    • Tilt the laptop's screen back.
    • Lift the panel and remove it from the laptop.
  8. Toshiba Satellite L35-S2174 Screen Replacement: stap 8, afbeelding 1 van 2 Toshiba Satellite L35-S2174 Screen Replacement: stap 8, afbeelding 2 van 2
    • There is a ribbon cable underneath the keyboard. Don't lift the keyboard too forcefully or you may break the ribbon cable.
    • Unclip the keyboard from the laptop by lifting it.
    • Slide the keyboard slightly towards the screen.
    • Lift the keyboard out of the way.
  9. Toshiba Satellite L35-S2174 Screen Replacement: stap 9, afbeelding 1 van 1
    • Pull the ribbon cable straight out of the connector.
    • To reinstall the cable, hold it near the end and push it straight into the connector, being careful not to kink the cable.
  10. Toshiba Satellite L35-S2174 Screen Replacement, Screen: stap 10, afbeelding 1 van 2 Toshiba Satellite L35-S2174 Screen Replacement, Screen: stap 10, afbeelding 2 van 2
  11. Toshiba Satellite L35-S2174 Screen Replacement: stap 11, afbeelding 1 van 2 Toshiba Satellite L35-S2174 Screen Replacement: stap 11, afbeelding 2 van 2
    • Unscrew the two circled screws with a J1 screwdriver. The screws will remain attached to the plastic panel.
  12. Toshiba Satellite L35-S2174 Screen Replacement: stap 12, afbeelding 1 van 3 Toshiba Satellite L35-S2174 Screen Replacement: stap 12, afbeelding 2 van 3 Toshiba Satellite L35-S2174 Screen Replacement: stap 12, afbeelding 3 van 3
    • Gently lift and detach the grey and black antennae cables that are attached to the blue circuitboard.
    • To reinstall, hold the connectors in place and gently press them straight down. The connectors “snap” into their sockets much like the metal snaps on a jacket.
  13. Toshiba Satellite L35-S2174 Screen Replacement: stap 13, afbeelding 1 van 1
    • Flip the laptop over.
    • Pull the black and grey cables out of the laptop, towards the laptop screen.
    • The cables are connected to the screen.
  14. Toshiba Satellite L35-S2174 Screen Replacement: stap 14, afbeelding 1 van 2 Toshiba Satellite L35-S2174 Screen Replacement: stap 14, afbeelding 2 van 2
    • Detach the black cable from the computer by pulling it to the right.
  15. Toshiba Satellite L35-S2174 Screen Replacement: stap 15, afbeelding 1 van 1
    • Lift the screen away from the laptop.
Conclusie
Amani Mitchell
401 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 1-4, Catania Fall 2016 Lid van UMass Dartmouth, Team 1-4, Catania Fall 2016
UMASSD-CATANIA-F16S1G4
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 374
