Ga door naar hoofdinhoud
Toshiba Satellite L35-S2174 Keyboard Replacement
Wat je nodig hebt
  1. Toshiba Satellite L35-S2174 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the laptop off to prevent the possibility of electric shock or damage to the computer.
    • Flip the laptop so that the bottom is facing upwards.
  2. Toshiba Satellite L35-S2174 Keyboard Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite L35-S2174 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Slide the battery lock switch to the left.
  3. Toshiba Satellite L35-S2174 Keyboard Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite L35-S2174 Keyboard Replacement: stap 3, afbeelding 2 van 2
    • Pull the sliding switch to the right and continue to hold it in this position.
  4. Toshiba Satellite L35-S2174 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • While holding the switch, slide the battery away from you.
    • You do not need to hold the switch when putting the battery back into the laptop.
  5. Toshiba Satellite L35-S2174 Keyboard Replacement, Keyboard: stap 5, afbeelding 1 van 2 Toshiba Satellite L35-S2174 Keyboard Replacement, Keyboard: stap 5, afbeelding 2 van 2
    • Remove the two circled 4mm screws with a J1 screwdriver.
  6. Toshiba Satellite L35-S2174 Keyboard Replacement: stap 6, afbeelding 1 van 2 Toshiba Satellite L35-S2174 Keyboard Replacement: stap 6, afbeelding 2 van 2
    • Remove the two circled 5mm screws with a J1 screwdriver.
  7. Toshiba Satellite L35-S2174 Keyboard Replacement: stap 7, afbeelding 1 van 2 Toshiba Satellite L35-S2174 Keyboard Replacement: stap 7, afbeelding 2 van 2
    • Use a spudger to pry up the plastic panel between the keyboard the screen.
    • Repeat on opposite side of laptop.
    • The panel may be difficult to remove.
    • Tilt the laptop's screen back.
    • Lift the panel and remove it from the laptop.
  8. Toshiba Satellite L35-S2174 Keyboard Replacement: stap 8, afbeelding 1 van 2 Toshiba Satellite L35-S2174 Keyboard Replacement: stap 8, afbeelding 2 van 2
    • There is a ribbon cable underneath the keyboard. Don't lift the keyboard too forcefully or you may break the ribbon cable.
    • Unclip the keyboard from the laptop by lifting it.
    • Slide the keyboard slightly towards the screen.
    • Lift the keyboard out of the way.
  9. Toshiba Satellite L35-S2174 Keyboard Replacement: stap 9, afbeelding 1 van 1
    • Pull the ribbon cable straight out of the connector.
    • To reinstall the cable, hold it near the end and push it straight into the connector, being careful not to kink the cable.
Conclusie
Amani Mitchell
401 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 1-4, Catania Fall 2016 Lid van UMass Dartmouth, Team 1-4, Catania Fall 2016
UMASSD-CATANIA-F16S1G4
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 338
