Ga door naar hoofdinhoud
Toshiba Satellite L305D-S5950 Motherboard Replacement
Wat je nodig hebt
  1. Toshiba Satellite L305D-S5950 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 Motherboard Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite L305D-S5950 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 Motherboard Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite L305D-S5950 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 Motherboard Replacement, Hard Disk Drive: stap 5, afbeelding 1 van 2 Toshiba Satellite L305D-S5950 Motherboard Replacement, Hard Disk Drive: stap 5, afbeelding 2 van 2
    • Unscrew the screws enough to remove the top cover.
  6. Toshiba Satellite L305D-S5950 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Remove the cover by lifting the right side up at an angle before removing the entire cover.
  7. Toshiba Satellite L305D-S5950 Motherboard Replacement: stap 7, afbeelding 1 van 2 Toshiba Satellite L305D-S5950 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Remove the hard drive from the SATA slot by tugging lightly on the ribbon cable to the right.
  8. Toshiba Satellite L305D-S5950 Motherboard Replacement: stap 8, afbeelding 1 van 3 Toshiba Satellite L305D-S5950 Motherboard Replacement: stap 8, afbeelding 2 van 3 Toshiba Satellite L305D-S5950 Motherboard Replacement: stap 8, afbeelding 3 van 3
    • To separate the hard drive from the caddy, unscrew the two screws.
  9. Toshiba Satellite L305D-S5950 Motherboard Replacement, RAM: stap 9, afbeelding 1 van 3 Toshiba Satellite L305D-S5950 Motherboard Replacement, RAM: stap 9, afbeelding 2 van 3 Toshiba Satellite L305D-S5950 Motherboard Replacement, RAM: stap 9, afbeelding 3 van 3
    • Unscrew the RAM cover and rotate the cover up to remove it. The screw should not be fully removed from the cover itself.
  10. Toshiba Satellite L305D-S5950 Motherboard Replacement: stap 10, afbeelding 1 van 2 Toshiba Satellite L305D-S5950 Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Push the small levers at the sides of the RAM module away from each other. The RAM module should automatically rotate upwards.
  11. Toshiba Satellite L305D-S5950 Motherboard Replacement: stap 11, afbeelding 1 van 2 Toshiba Satellite L305D-S5950 Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Remove the RAM module by pulling it out at the angle it was rotated to.
  12. Toshiba Satellite L305D-S5950 Motherboard Replacement: stap 12, afbeelding 1 van 3 Toshiba Satellite L305D-S5950 Motherboard Replacement: stap 12, afbeelding 2 van 3 Toshiba Satellite L305D-S5950 Motherboard Replacement: stap 12, afbeelding 3 van 3
    • If you want to replace the second RAM module, apply steps 2 and 3 to do so.
  13. Toshiba Satellite L305D-S5950 Motherboard Replacement, Keyboard: stap 13, afbeelding 1 van 2 Toshiba Satellite L305D-S5950 Motherboard Replacement, Keyboard: stap 13, afbeelding 2 van 2
    • Locate the plastic strip at the top of the keyboard.
    • Use a pry tool to remove the plastic strip.
    • Using your hands pull out the rest of the plastic strip.
  14. Toshiba Satellite L305D-S5950 Motherboard Replacement: stap 14, afbeelding 1 van 1
    • Use a phillips head #0 screwdriver to remove the two 3.75mm screws holding the keyboard in place.
  15. Toshiba Satellite L305D-S5950 Motherboard Replacement: stap 15, afbeelding 1 van 3 Toshiba Satellite L305D-S5950 Motherboard Replacement: stap 15, afbeelding 2 van 3 Toshiba Satellite L305D-S5950 Motherboard Replacement: stap 15, afbeelding 3 van 3
    • Lift up the top of the keyboard to remove it.
    • Under the keyboard there is a ribbon cable connecting the keyboard to the laptop. Do not just quickly pull out the keyboard.
    • Unlock the ribbon cable by pushing on the locks that are located on both sides of ribbon cable.
    • Unplug the ribbon cable from the laptop.
  16. Toshiba Satellite L305D-S5950 Motherboard Replacement: stap 16, afbeelding 1 van 1
    • Remove the keyboard completely from the laptop.
  17. Toshiba Satellite L305D-S5950 Motherboard Replacement, Motherboard Cover: stap 17, afbeelding 1 van 2 Toshiba Satellite L305D-S5950 Motherboard Replacement, Motherboard Cover: stap 17, afbeelding 2 van 2
    • Remove all 6.75mm screws from the bottom of the laptop. The 3 screws under the battery are 3.75mm.
    • Remove all 5.25mm screws from the top of the laptop.
  18. Toshiba Satellite L305D-S5950 Motherboard Replacement: stap 18, afbeelding 1 van 3 Toshiba Satellite L305D-S5950 Motherboard Replacement: stap 18, afbeelding 2 van 3 Toshiba Satellite L305D-S5950 Motherboard Replacement: stap 18, afbeelding 3 van 3
    • Unplug the wires highlighted with red squares.
    • Using a pry tool and yours hands to remove the motherboard cover.
  19. Toshiba Satellite L305D-S5950 Motherboard Replacement, Motherboard: stap 19, afbeelding 1 van 1
    • Unscrew all the screws indicated by the red circles (The bottom two screws are 10.75mm and the top screw is 5mm).
    • Unplug all the wires indicated by the orange squares.
    • Some wires may have a lock on them that needs to be pulled out before the wire is removed.
  20. Toshiba Satellite L305D-S5950 Motherboard Replacement: stap 20, afbeelding 1 van 1
    • At this point the motherboard can be fully removed from the laptop.
Conclusie
6 andere personen hebben deze handleiding voltooid.
William
875 Reputatie
7 handleidingen geschreven
Clemson, Team 1-2, Benson Spring 2014 Lid van Clemson, Team 1-2, Benson Spring 2014
CLEM-BENSON-S14S1G2
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 2,391
