Ga door naar hoofdinhoud
Toshiba Satellite L305D-S5950 Motherboard Cover Replacement
Wat je nodig hebt
  1. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement, Battery: stap 1, afbeelding 1 van 1
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: stap 2, afbeelding 2 van 2
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: stap 3, afbeelding 2 van 2
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: stap 4, afbeelding 1 van 1
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement, Keyboard: stap 5, afbeelding 1 van 2 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement, Keyboard: stap 5, afbeelding 2 van 2
    • Locate the plastic strip at the top of the keyboard.
    • Use a pry tool to remove the plastic strip.
    • Using your hands pull out the rest of the plastic strip.
  6. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: stap 6, afbeelding 1 van 1
    • Use a phillips head #0 screwdriver to remove the two 3.75mm screws holding the keyboard in place.
  7. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: stap 7, afbeelding 1 van 3 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: stap 7, afbeelding 2 van 3 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: stap 7, afbeelding 3 van 3
    • Lift up the top of the keyboard to remove it.
    • Under the keyboard there is a ribbon cable connecting the keyboard to the laptop. Do not just quickly pull out the keyboard.
    • Unlock the ribbon cable by pushing on the locks that are located on both sides of ribbon cable.
    • Unplug the ribbon cable from the laptop.
  8. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: stap 8, afbeelding 1 van 1
    • Remove the keyboard completely from the laptop.
  9. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement, Motherboard Cover: stap 9, afbeelding 1 van 2 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement, Motherboard Cover: stap 9, afbeelding 2 van 2
    • Remove all 6.75mm screws from the bottom of the laptop. The 3 screws under the battery are 3.75mm.
    • Remove all 5.25mm screws from the top of the laptop.
  10. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: stap 10, afbeelding 1 van 3 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: stap 10, afbeelding 2 van 3 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: stap 10, afbeelding 3 van 3
    • Unplug the wires highlighted with red squares.
    • Using a pry tool and yours hands to remove the motherboard cover.
Conclusie
John Drinkwater
329 Reputatie
1 Handleiding geschreven
Clemson, Team 1-2, Benson Spring 2014 Lid van Clemson, Team 1-2, Benson Spring 2014
CLEM-BENSON-S14S1G2
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 286
