Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Locate the two sliding battery locks on the underside of the laptop.
Locate the right battery lock and slide it to the right.
While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
Locate the plastic strip at the top of the keyboard.
Use a pry tool to remove the plastic strip.
Using your hands pull out the rest of the plastic strip.
Use a phillips head #0 screwdriver to remove the two 3.75mm screws holding the keyboard in place.
Lift up the top of the keyboard to remove it.
Unlock the ribbon cable by pushing on the locks that are located on both sides of ribbon cable.
Unplug the ribbon cable from the laptop.
Één opmerking
I have a Toshiba Satellite L305D. A glass of tea was spilled on it several months ago and I just turned it on and it is working but some of the keys do not work, shift, letter a and several more. If I replace the keyboard will this fix this problem or are there more parts that should be replaced? Thanks, Pam
